GiffS Follow up question the ASIAIR did not do any sort of calibration last night. Should I force one somehow tonight?
Are you on a tripod instead of a permanent pier? If so, you must recalibrate for PHD2 to get the correct RA-dec vs x-y pixel relatonship (what "calibration" does).
On ASIAIR, force it in the small guide window.
One possibility is that I could probably tighten up my focus on the ASI120MM it is a little sloppy but it worked fine on the AVX,
If you are using multi-star guiding, you need a perfectly focused image on a plate that is wide and completely flat. Use a decent guide scope with a field flattener, and with a camera that has a large sensor. Otherwise you will find ASIAIR multi-star guiding to go wonky after 1/2 and hour or so, and you are better off with single star guiding. I suspect that with your mount, 2-second exposures with single stars will do fine.
Make sure to follow the documentaton religiously, and calibrate near the celestial equator. Do not calibrate guiding at your target if your target is more than 20º or 30º from the equator.
As usual, ASIAIR is giving something really simple like autoguiding a bad name.
