If you have a dark filter in slot #1 Plan modes don't work unless you manually change the filter to something else before starting the plan.
Allow the user to select the default power on slot # (other than current slot #1 default)
SteveD the filter wheel position can be set when you create the sequence.
I know, but the initial move to the target uses default position #1. Only after the plate solving does it change to the Plan filter.
SteveD Got it, we will test it and improve the process. thank you for your feedback.
