GoKidd I am using a fully-ZWO setup for mount, cameras and EAF.
The ASIAIR only supports the EAF and astro cameras.
That being said, I have been using a non-ZWO strain wave mount since May of 2019 on the ASIAIR, once ZWO finally got a mount (and RST-150h) on loan for code development. You should have seen the "quality" of the code before RainbowAstro took pity, and gave them a free loaner. Autoguiding has also been working well with the non-ZWO mount (way better than ZWO mounts FWIW) too, once it became available on ASIAIR.
Many of the problems for ASIAIR is that ZWO has never even touched one of those remaining troublesome mounts, and their developers are very poor at reading engineering documents -- they need a real mount to work on. I think they use trial-and-error coding.
The same is probably true with the DSLR and mirrorless cameras. They are too cheap or too poor to buy them for code development.
