keith.everett the T-2 spacer on the front of the camera won't unscrew or come off in any way. It's stuck on,
When threads are stuck, one thing that can help is to compress the threads before turning. I.e., press the two parts together with as much force as you can, and then turn. Some people use rubber soles of sneakers to do the compressing.
Jar openers might also help. It spreads the force across the circumference, instead of distorting the spacer (althrough the ZWO spcer is so thinck, it is not likely to distort).
http://www.amazon.com/MEYUEWAL-Children-Arthritis-Sufferers-Silicone/dp/B07G2WW21S
In general, ZWO spacers are terrribly machined. Just compare them with spacers from preciseparts.com, which had never seized on me.
