Same months ago my A6000 works well, now it take only a picture end nothing else, do you have notice!
Bibi64 Usually it related on some settings on the camera, please check some additional function is off, such as power saving, AEB, etc.
Tech@ZWO There is no way to turn off power saving on the A6000. The only setting allows you to set the Power Saving Start Time to a maximum of 30 minutes. Power Saving should not be an issue as long as the camers is in use taking exposures.
Tech@ZWO ho risolto con il reset di fabbrica! Grazie a tutti!
So, going back to 2.1 version and relate FW the camera seems to work again, but not continuosly, it take one picture and nothing else. Nobody as the same problem?
Bibi64 Try restoring the camera to factory Settings?
Tech@ZWO i tried to reset, i'm afraid to hard reset, i have some program istalled, may be i lost that programs?
Tech@ZWO Ho risolto con il reset di fabbrica! Grazie !
mkctex Hi, do you using A6000 yet?
Yes, I use the A6000 all the time. However, I have put away the ASIAir for now because there are just too many bugs in the software. I am just using the mount hand controller (Star Avventurer GTI) and and intervalometer.
So... I solved! I reset to factory the A6000 and everyting goes well! I'm happy. Sorry for my english... thanks to how helps me!
