There seems to be no way to save images to the memory card in the camera. Am I missing something?
mkctex Enable the 'save the images to DSLR simultaneously' option in the main camera settings.
There is no such setting there. Others using Sony Mirrorless cameras have confirmed that. I know exactly what you are saying because I saw that setting on a screenshot for a Canon camera, but it is not on the camera settings for the Sony A6000.
mkctex My mistakes, i just confirmed with our team, Sony cameras do not support to save the images to DSLR simultaneously when working with ASIAIR.
Same months ago my A6000 works well, now it take only a picture end nothing else, do you have notice!
Bibi64 Usually it related on some settings on the camera, please check some additional function is off, such as power saving, AEB, etc.
Tech@ZWO There is no way to turn off power saving on the A6000. The only setting allows you to set the Power Saving Start Time to a maximum of 30 minutes. Power Saving should not be an issue as long as the camers is in use taking exposures.
So, going back to 2.1 version and relate FW the camera seems to work again, but not continuosly, it take one picture and nothing else. Nobody as the same problem?
Bibi64 Try restoring the camera to factory Settings?
