Hey there!
I've recently updated my ASIAir Firmware to 11.01.
Because of the Firmwareupdate I had to update my ASIAir App on my BlueStacks instance as well.
I wasn't able to install the App 2.1.2 on my Nought 32 / 64 bit instance of Bluestacks so I updated BS to Version 5.21.111.1001 and had to use Pie 64 bit otherwise I wasn't able to install the .APK.
After installing the .APK I wasn't able to connect to my ASIAir.
The ASIAir App says that there is no mobile network connection, but this isn't true because I'm able to use Google Chrome, Playstore and so on without any issues. With my real cellphone everything is fine and I can connect to my ASIAir.
The ASIAir is in station mode and connected via LAN to my router.
Before the update my mobile network on the ASIAir App on BS was called "BlueStacks"
Tried the update on two different PC with two different BS instances. I've als tried using Android 11 instead of Pie 64 bit. Same result: "No Network"
Did I miss something in the settings?
Does anyone have the same issue?!
