Kevin_A Even having filter changes that are 1.85mm vs 2mm is enough to have to change my shims.
The FSQ-85 is sensitive to even 0.1mm of backspace too (if you care about getting small stars) for Takahashi's native 56.2 mm number. (I have not yet figured out why such weird backfocus number, but it is uniform for all of their FSQ flatteners and reducers; and they are serious about the "0.2mm" part :-).
I have a couple of sets of the Agena Blue Fireball metal spacers that go from 0.1mm to 1mm in 0.1mm steps to handle the Taks. None of the silly 3D printed spacers (and Baader's metal spacers don't have enough resolution); thank god for Blue Fireball (Agena house brand?).
https://agenaastro.com/blue-fireball-9-pc-fine-tuning-spacer-ring-set-for-m54-threads-0-1-to-1-0-mm-s-set9.html
Their M54 tube spacers are also quite good -- threads almost as smooth as the custom stuff from PreciseParts.
Heavier clouds came in by the time Corona Borealis appeared over the tree tops, so never got to take my pre-Nova reference photo.
The price vs sharpness is fabulous to say the least.
I concur. This appears to be one sharp lens for its price (especially after having gone through Canon-L and Sigma-ART lenses). I tried both f/3.85 and f/2.9 last night, and the f/2.9 does not appear to suffer much at all from f/3.85 for APS-C frames. (Weird numbers are from step down rings and the camera filters after removing the glass.) Its usefulness is somewhere between APS-C and full frame (I was testing with an ASI6200MC). I might stick to f/2.9; less than 1/2 stop difference though, FWIW.
