- Edited
Kevin_A Just be aware that these lenses are mostly plastic
Not just plastic, but the "thinnest of plastic" :-)
https://www.cloudynights.com/topic/837977-rokinon-135-lens-repairupgrade/
If I plan on destroying the lens just to educate myself anyway, it won't be disappointing if I can't put it back together afterwards. I have never taken apart any OTA either, for fear of losing collimation.
Thanks for the warning. I shall try not to torque it too much, in case I go through with it.
This guy's lens did not survive :-)
https://www.dpreview.com/forums/post/62158943
Did you actually remove enough to get to the iris? If so, is it sufficient to remove just from the back screws?
Appears to be possible:
https://www.flickr.com/groups/365610@N21/discuss/72157625882212905/
Hmmm, I should at least remove the infinity focus stop of the lenses (including my current Rokinon) so that the EAF don''t hit a hard stop (especially when using ASIAIR "autofocus"). To be safe, I have set the EAF up so that the hard stop corresponds to 0 EAF step size. But the interesting thing is that with the 13.5mm camera angle rotator (instead of a "proper" 15mm spacing), infinity focus is actually at 30 ft instead of infinity, so I am extra safe. (BTW, the camera angle rotator has the Blue Fireball badge, which is the Agena house brand.)
