- Edited
Kevin_A I had a fairly clear night 2 days ago so I tested my 135mm at f2.8 with the exact backfocus shims inserted.
OK, this is looking down the Samyang 135/2.0 lens barrel from the front element.
Fixed aperture is controlled by the ZWO fisheye lens that sacrificed its retaining ring for a better purpose.
This is with the Samyang's aperture control closed up to f/8:
Whew.
We'll find out what I screwed up when I point it at the stars. I will at least try a normal terrestial image tomorrow when there is daylight. Raining just moments ago :-). If I screwed up badly, I will just buy another one, and use its native iris *spikes", but with M54 instead of bayonet. If I didn't screw up, this might make it the best Samyang 135 on earth :-).
BTW, the front element of this second Samyang has two thin brass shims. The first one did not.
There are not many steps. I left most of the back part alone. Just had to remove up to the aperture control ring. Had to remove the cosmetic focusing scale shell, though, to expose those three focuser attachmentscrews (in nylon). If I have to do it again, I will make sure they don't fall out, but with the screw retracted a little so that the rear group barrel can slide in and out. But leave one screw out of the plastic, so that we can line up one screw to its mating threaded hole in the rear group.
Definitely don't think 99% of the unwashed masses should attempt this. They can't even level a SeeStar :-).
BTW, with the EOS bayonet removed, I had some 3.8mm to 4.3mm of backfocus left after installing the Askar backfocus adjuster. set to 18mm I am guessing the actual numbers since I am just using a tree 70 yards away to judge, and using geometric optics to calculate the difference to infinity focus.
BTW, foliage was a terrible muddy brown with the AR window of the cooled ASI585 (AR window). But I am not installing any internal filters, since I don't trust even the IDAS filters to work at f/2 or f/2.4.
I just ordered a couple of generic 82mm didymium filters to place on the lens' filter thread (people use them for MIlky Way photos to remove the sodium city lights). It may not cut the UV, though, so I may have to invest in a 82mm B&W or Zeiss UV filter too. Any cheaper glass will ruin the good lens.
Hoya has a 82mm that will cut both UV and IR, but I fear even good Hoyas will ruin a good lens. But I am willing to try.
Using a cheap filter is like putting a $20 SVBONY filter on a $4000 astrograph.
With the QHY 10mm thick EOS adapter, I would have 16.5mm worth of backfocus, thus being able to use just the last 0.5mm of the backfocus adjuster (18mm +/- 2mm). Might work, and if so, just barely. With the thinnest ZWO EOS adapter, I would be 3mm short, which means there is no way to use the backfocus adjuster.
I can't install a camera rotator with the backfocus adjuster in place. But I can do without it when trying to measure backfocus as long as the tilt is small.
