starvoyager They advised I should be using Flat Darks instead
Yes, use flat darks, not bias frames -- some call them dark flats, but they are esentially flat frames that are taken with the same exposure settings as the flats, but with no light entering the camera. I.e., the same temperature, exposure duration and gain as you take flats. Bias will be incorporated in the dark frames already, and you can create a Master Flat by incorporating these dark frames.
The temperature does not have to be the same as your Light frames. I do my ASI2600 light frames at -10ºC (already an overkill), but then to do my Flats and Flat Darks indoors at +10ºC.
Be sure to use the same temperature for Flats and Flat Darks -- that is what makes Flat Darks work so well. With some sensors, like the one in ZWO's ASI294, you must use Flat Darks since the sensor is so unpredictable with temperature. The IMX571 in the ASI2600 is much better behaved, but it still doesn't hurt to use Flat Darks.
Since the Flat Darks take the same exposure time as the Flat frames, this will slow you down compared to what you are doing today (taking bias frames).
But, just 16 to 32 flat and dark subexposures should be sufficient (32 subframes will reduce the noise by about 15 dB, and that should be sufficient to not affect the noise of the final image). If you use a single flat frame, for example, it would double the noise and reduce Signal to Noise (SNR) ratio by 3 dB. 16 flat frames should reduce the noise of the Master Flat already by about 12 dB, and the resultant image will only suffer SNR degradation of less than 0.1 dB (you won't even notice it :-).
Do not use regular dark frames (taken at the temperature of the light frames). Just use the same temperature for the Flat Darks that you use for the Flats.
