Figzphotos I can not remove the filter draw because I use it for my LPro filter for light pollution.
The M54 spacer that is 15mm thick can also take a M48 filter:
https://astronomy-imaging-camera.com/product/zwo-m54-adapter-replacing-efw/
Remember that your Optolong filter glass is 2mm thick, so for backfocus purposes, you also need to add 0.66mm to the backfocus specs of the OTA.
I.e., if your OTA manufacturer tells you the backfocus from the metal back needs to be 55.00 mm, adding a glass of thickness L will make the optical path have 55.00 + L/3 backfocus. See Katie Schwertz' Master's thesis that I have linked multiple times to this forum.
All of ZWO's parts are aimed at 55mm mechanical backfocus, which is wrong for an OTA with 55mm backfocus, once there is any glass filter between the OTA and the camera.
