I just received, unboxed and attached the 2600 MM Pro to my rig. I powered it with its own 12V 5A DC power source and connected it to the PC by the supplied USB3 cable. It was not recognized by NINA, ASIStudio or TheSky. I tried 3 different USB 3 cables (all known to work) and 3 different 12V 5A power sources that output 12.87V on average. Nothing worked. I didn't notice that the tiny LED light just above the "power in plug" on the camera was blinking. I confirmed it should be steadily on. My question is, does anyone know if there's a significance to the blinking LED on ZWO cameras? I searched quite a bit and couldn't find anything about it. The place where I purchased the camera said they've never seen that. This is more a curiosity question as the seller shipped a new camera to me the same day I contacted them.
Thanks.
    JMS Blinking LED is not normal, sounds like the power connection is unstable.
    Thanks. I figured it wasn't normal but was curious what it indicates. So I appreciate your comment pointing to a power problem.
    Write a Reply...
