Well I might rescind everything I said. I ran a test indoors with my C-6 and the ASI662MC camera. Although it is not a C-11, I would think the functioning would be about the same. I was about 30 ft from an object to focus on. I used a 25mm eyepiece in a diagonal to center the object. I then replaced the eyepiece with the camera using the 1.25" nosepiece. The room which contained the object was not brightly lit so I adjusted the exposure to accommodate for that and began to adjust focus. I did not have to adjust the focus very far before I could achieve focus with the camera.
I have an 80mm refractor that I use for solar. It has an external Lunt H-a filter and a blocking filter diagonal. I use a different camera, but it has the same internal backfocus (12.5mm). I plug it right into the blocking filter using the 1.25" nosepiece and need no adapters.
So I don't know what to tell you. Try using a diagonal, focus with a low power eyepiece, then replace it with the camera. Adjust the exposure down until it is somewhat dark. The fixed exposure settings in ASILive are a nuisance. It is a pain to get the proper exposure if it lies between two very different settings. At that point you can adjust the gain to brighten the image. That also has fixed values so if that does not help, you either have to adjust both exposure and gain or set up new values. The other possibility is to try SharpCap. That has sliders for exposure adjustments.
JohnD
By the way, you will not be able to get a full solar disk with your Coronado and that camera. Check this site:
https://astronomy.tools/calculators/field_of_view/
You would need a focal reducer.
