Hi everyone,
I recently experienced exposure failures when using my Sony A7RV with a ZWO setup (ASIAIR etc.). The camera simply didn’t take any pictures during long exposures.
After working with ZWO support (thanks again, Bean!), I was able to solve the issue — and I’d like to share what worked for me in case it helps others.
The key solutions were:
1. PC Control: Set “Save in” to “Destination (PC)” instead of “Camera + PC”
2. USB Setting: Set to “PC Remote (Multi)” instead of “PC Remote (Single)”
3. Turn off Zebra Display
4. Set “Save Image Format” to “Original”
→ This prevents issues with the image being processed in-camera or saved incorrectly.
Once I made these changes, everything started working flawlessly with ASIAIR.
Here’s the full checklist provided by ZWO support, plus my additions:
✅ 1. Disable Exposure Bracketing
✅ 2. Disable Long Exposure NR (Noise Reduction)
✅ 3. Disable Electronic Shutter
✅ 4. Disable Silent Shooting
✅ 5. Disable Wi-Fi and Bluetooth
✅ 6. Set Camera Mode to Manual (M)
✅ 7. Use Bulb Mode (B)
✅ 8. Set Image Format to RAW
✅ 9. Insert a memory card
✅ 10. Set “Save Image Format” to “Original”
✅ 11. Set “PC Control > Save in” to “PC only”
✅ 12. Set “USB Connection” to “PC Remote (Multi)”
✅ 13. Turn off Zebra Display
If you’re having similar issues with the A7RV and ZWO, I highly recommend reviewing these settings. For me, it was mainly the PC Control “Save in” setting, the USB mode, and disabling the Zebra Display that fixed the exposure failure.
Hope this helps!
Clear skies,
Niklas
