Did you enter the right focal length for the main scope and guide scope?
Polar alignment works fine for me as always.
If you are using a onstep controller you need to ise a special driber for polar alignment only and then switch back.
johnpd
What telescope, mount, camera and reducers/Barlow were you using? I have a 2600 mc pro, with C9.25 on a CGX and with a focal reducer
Did you have any problems with the resolution of the plates? The problem is the continuous retry in taking the second shot
Were you performing the 60° rotation? Never performed it once, it always gave problems on the first shot
I too had a problem plate solving doing my PA. But mine was due to using a ultrawide 35mm lens. The minimum I find is about a 100mm lens. I just built a custom 35mm f1.4 fast cooled rig for milkyway season. Next time I will use my 120mm guide scope to do PA then switch my imaging scope back to the 35mm imaging rig.
Plate solve using my larger focal length scopes has not been an issue with my 135, 300, 550 and 805mm scopes after the update.
Another problem.
On my 12 GB Samsung S23 ultra, when starting the new version it heats up enormously and the battery consumption is excessive. When the camera initially cools down, the system temperature shows 9°C above the ambient temperature, in my case 25°C. If I set it to cool directly to -5°C when it reaches -1°C it shows that it is working at 100%, whereas just 3 days ago at the same temperature it was reaching -5°C at 85%. I have been able to solve it by cooling it little by little, first up to 25°C, letting it stabilize for a few minutes, then up to 15°C, 0°C and finally -5°C, this way it behaves well, but if it is done directly it increases to 100%.
PMTeam@ZWO when new features will be added to the asiair? For example add an option to choose how much you want to move the mount when doing polar alignment in my case I do not have view to the north and I have a building in the west but I have view to south west, part of the south, and north west, I always have to use N.i.N.A to do my polar alignment because they have the option to choose the degrees on how much you want the mount to move when doing the 3 sky polar alignment, add features to keep your customers happy and get more customers.
if you guys are having problems with lat/long and other things I went back to 2.1.2 and that seems to be the play till they fix there stuff atm for me not worth it
shawnhotz256 Going back only is possible if the older version of the app can be installed. This is not possible on iOS/iPadOS. That in itself is not a reason to abandon Apple products and switch to Android.
wvreeven ya sorry ment for android I went back to 2.1.2 I don't use apple so not sure if the problem is on there and by not worth I mean if you can use 2.1.2 probably better off there if you have this problem I have and can stick to that version not abandon phones isn't what I was trying to say my bad
