A chance to Motorfocus for the new Vixen VSD90ss??? I see on CloudlyNights a picture...
https://www.cloudynights.com/uploads/monthly_05_2024/post-214850-0-69150500-1715991898.jpeg
AlexanderHornung Sorry, this Photo:
Can't you drive the focuser shaft of your Vixen directly? Gears can add more backlash.
FWIW, this is how I drive a Vixen FL55SS's focuser:
Hi Chen, you have right. Gears can add more backlash, but...Which motor do I have to order so that it really fits on the Vixen VSD 90ss?
AlexanderHornung Which motor do I have to order so that it really fits on the Vixen VSD 90ss?
The EAF can be made to fit, but the Q-Focuser is a much better focuser for a similar price point. Better electronic drives are available if you are willing to pay more.
You might be able to fit the high end Q-Focuser on the 10:1 step down side of the OTA focuser. That would practically get rid of backlash.
You can fit anything if you are willing to do some machining yourself. As I said earlier, direct drive your focuser. Remove that black knob to see what the shaft diameter is, and couple it to something like the EAF (which has a 5mm shaft). I would be surprised if that shaft has a non-common diameter, or even different from my FL55's shaft.
Thank you very much Chen for your help!!! Great!!!
Greetings to you, Alexander
