Hello,
I would like to be able to start the mount with the DEC axis at 90° as a fixed position so that I can have a dovetail mounted horizontally with two side-by-side telescopes.
Could you implement this home option in future firmwares, please?
Thanks a lot!
Manel Marin.
(Spain)
    @Manel.Marin
    Many have asked for a separate Park and Home position.
    Would love this to be implemented.
    At it stands right now the Home position on the ASIAIR is set when you turn the ASIAIR on and it first connects to your mount.
      @Manel.Marin
      Corsair
      Some mounts support rotating the dovetail 90 to install, such as AM5, in this case, you can remove the dovetail, and then rotate 90 degrees to install the two side-by-side telescopes, no need to change the home position in the ASIAIR app.
      I also recorded this suggestion and forwarded to our ASIAIR team. thanks,
      Write a Reply...
