When I start the ASIair it always reverts to coordinates showing N 39 54'35" E 116 23' 50", somewhere in Beijing, China (I'm near Nashville TN, USA). Oddly enough, it doesn't change the time zone from -6, obviously incongruent with the location.
I have my location set correctly inside bluestacks and in Windows, and location service is allowed. If I tell the AIR to refresh location, the popup indicates that it has success, but it still shows the incorrect Beijing coordinates. When I correct the coordinates manually, it remains correct when I proceed, but any restart of the device means I have to manually enter the coordinates again.
I'm not aware of any way to have the AIR retrieve coordinates from the mount. The synchronize button sends the the ASIair location info to the mount.
FYI, mount (Losmandy G11G with Gemini II) and ASIair are connected via Ethernet. I had no issues for years. The change happened when I had a hard drive crash and Windows re-install, which meant a re-install of everything, including bluestacks and the new version of ASIair. I haven't changed any settings that I'm aware of, and it's simple enough software so I'm probably missing something obvious.
