Your camera angle adjuster could be sticking too far into the EFW, cause the EFW's bearings to become loose.
If so, try removing the CAA, or at least add some shims/stop rings, so that ithe CAA does not stick so deeply into the EFW, then go in to tighten the EFW bearing. There are three smal scres holding the EFW bearing (at center of the filters) make sure they are tight.
The EFW is very cheaply designed, and moves by friction only, between the bearing of the stepper motor and a large rubber O-ring that goes around the carousel of the EFW. Make sure the O-ring is properly seated.
Then, finally go to some ZWO program (like ASIStudio) and do a "calibrate" of the EFW. See if the fiters are centered, after that.
Lets hope you did not scratch the filter glass.
