[deleted] May I ask if you want to delete your BBS account?
Yes exactly, I would like to delete my BBS account:-) not using it anymore
[deleted] OK, I'll take care of that for you.
[deleted] You can delete it at this URL: https://account.seestar.com/account
AstroImg@ZWO unfortunately the link does not work for me:
[deleted] Click "注销": https://account.seestar.com/delete
AstroImg@ZWO
Hello, Actually I also want to delete my account, since I will change and move to another NEW prodcut, and I did try to delete my account with the above link, but the same error is still generated as above " request failed with status code 401 "
How can I delete my account/access/log-in at https://bbs.zwoastro.com ???? Martin
artem Please ignore the error message and click here
well, ive done ALL that but still my account is here.
AstroImg@ZWO ive been patient with many things, like my astro fellow starnet 😉 but now is my time to move on.
Can you just delete my account and all data connected manually?
[deleted] OK, I will report this to the technicians.
[deleted] I can process the deletion for you, but once deleted, your AstroNet, Seestar, and BBS accounts will also be deleted because they are the same account. Are you sure you want to delete?
AstroImg@ZWO yes im sure that i want to have it all deleted 🙂 if anytime i need access again i will recreate a new account.
Thank you for the help!
@AstroNet@ZWO I would also like to delete my account. I tried via your link, but still my account is here.
