Hi all,
I've had relatively good success using the Celestron CGX with the ASIAIR Pro over the past few years, as long as I follow a specific process:
- Start the mount, validate the position, time, and the last alignment, and decrease the speed to 1.
- Connect the Nexstar+ to the ASIAIR Pro via USB.
- Boot up the ASIAIR Pro.
However, after performing recent software updates, I encountered issues:
- Updated the Nexstar+ App from version 4.1.360 to 5.35.3175.
- Updated the CGX Motor Controller from 7.17.25 to 7.18.2214.
- Updated the ASIAIR Pro to version 2.1.5.
During my test, I found it nearly impossible to polar align (PA) with the ASIAIR Pro (V2.1.5). The mount experienced "slewing issues" during PA. Initially, the plate solves quickly, and the ASIAIR Pro prompts a 60° rotation. The mount begins rotating, but the percentage indicator on the screen doesn't progress ("RA Axis rotated 0.0 degrees"). After a while, the mount stops (well beyond 60°), and the ASIAIR Pro displays "Rotation Stopped RA Axis rotation stopped..."
Has anyone else experienced this issue or found a solution?
Celestron CGX users like sompi68 or SFj9LuNr, I've read your messages and would appreciate any additional tips or tricks. I can't figure out what I'm doing wrong.
For ASIAIR support, maybe we should consider joining the beta testers for Celestron mounts, as we frequently face issues with each new software release.
CGX Mount
Newton 250/1000
AsiairPro
