I've noticed over three nights using this release the PA routine doesn't work with my AVX mount.
PA starts by taking an initial photo.
Then it wants to slew 60 degrees and I click to continue
The mount starts the slew but the RA degree counter doesn't change, it remains at 0. About 1/2 the mount speed changes to a lower speed.
The mount seems to stop in the right place but ASIAir never takes the next photo. It hangs until you take action to Cancel.
I then switched to NINA and I encountered slewing issues in its polar alignment
I figured it was the mount.
The next night after setting up from scratch the ASIAir PA worked as normal.
This latest session, the third session with this release, ASIAir Polar Alignment problem ouccred. I switched over to NINA but didn't experience slewing issues when performing its polar alignment.
KJR
ZWO tech states the log shows the AVX never sends the RA/DEc coordinates back to ASIAir.
