ASIair can be used for guiding, imaging, and polar alignment with a tracker but support could be improved when mount is set to On Camera ST4 or None:
- Remove pointing arrow block and all references to "GoTo".
- Remove GoTo option in target selection and keep Center option which locates a red box in Sky Atlas at the target location.
- After plate solve remove GoTo and Sync options and add Center option to add current pointing location with blue box in Sky Atlas. Match up rotation of red box with blue box.
- Implement Pointing Assistance in Sky Atlas by using continuous plate solve and allowing user to manually move the mount to match up current location blue box with target red box.
