starnet59 As promised, here is my attempt at a 3D printed fixed equatorial wedge for the S50:
The total cost, including nut and bolt hardware from Home Depot, is under $3. As mentioned earlier, I am willing to create STL files for every latitude in steps of one degree and share them freely. But before doing that, I am looking for one or two people interested in printing one for themselves and providing feedback. I will send you an STL for your latitude and you will need one 3/8"-16x1" screw and one 3/8"-16 nut. The print takes 4h30m on my BambuLab X1C printer and either PETG or PLA should be fine. The nut is captive, your printer/slicer combination needs to be able to pause the print so you can insert the nut and then continue. Please be aware that for latitudes below 40 degrees the S50 on the ZWO tripod is not stable, even with the legs fully extended, you will need a tripod with much longer legs. This is true for any type of EQ wedge, not just this one.
If you are interested in giving this a try and provide feedback, please contact me at the e-mail address starnet at rogers dot com with your latitude and I will send you an STL and instructions on how to slice and print the thing.
After I receive feedback from a few testers and implement any potential changes, I plan to release the 90 STLs on makerworld.com and printables.com so anybody can access them for free.
