Hello all,
I am trying ASIAIR mini for the first time - with a Celestron C8 mounted on a Nexstar AZ mount.
The App has the correct Date/Time and LAT/LONG data input
I can confirm this because the Altas view is identical to my Stellarium view - objects are in the same exact location.
The unit can also perform plate solving successfully - and appears to calculate the correct location.
However - when I perform a GOTO - it moves sometimes 45 degrees off target
If I do a plate-solve again and a GOTO again - it simply resets the mount position on the same incorrect location.
In this setup I have not bothered to do any star alignment with the Nexstar mount all by itself because I assume the ASIAir is performing all of the GOTO calcuations - and simply sending X/Y movement commands to the mount.
Your help appreciated!
