Hello, I have had my Seestar since January and just noticed this last night while imaging. Have you received a response from anyone regarding this since your post Arriba??
CdnBVR I have send a video regarding blinking light to support. Answer: "Hello, currently, there seems to be no abnormality from the video. Are there any abnormalities in other aspects when using it?"
I would appreciate an option to switch of all LEDs during operation the Seestar.
Brille Are you trying to turn off the LED lights? I will give feedback on what you want.
support yes, optionally switching off all lights via app would be great. I sometimes place the Seestar overnight somewhere in the publicly accessible outdoor area near my house and it would be great if it could stand there rather discretely.
Hello, are you connected to an external charging unit, if the Seestar is on the charging indicator will flash.
support With or without external charging unit, indicator is flashing
Brille Hello, I understand your need, this may take a while. If you urgently need this feature, you can cover the LEDs with black tape.
Arriba If you are charging at the same time, the indicator light will flash.
support With or without external unit indicator is flashing
I paid attention to it last night. During enhancing the yellow start button is slowly flashing. No external unit.
Bobby2 So i am not the only one, you describe better and more exactly what I meant 17 july.
I think it's normal. That way you know the seestar it's enhancing. My does that.
