Hello,
The data downloaded from my ASI071 when I ask for MONO8 or RAW8 format images contains errors. The data in both cases does not properly cover the 8-bit range 0 to 255. In the case of the MONO8 images the maximum data value is 219!???!!!!*!!
The ASI071 is said to provide 14 bit output. Does this mean that the MONO8 and RAW8 image formats do not work properly and should not be used with this camera?
The RAW16 and RGB24 format images appear to work properly and data from the RAW16 image scales down properly to 8 bits when I do it in my own software.
Thanks in advance,
rogue.
