Here's the fits header from an image taken earlier this month. It does have color. The only difference I see is the NAXIS is 3. How do I control that from ASIAIR?
SIMPLE = T / file does conform to FITS standard
BITPIX = -32 / number of bits per data pixel
NAXIS = 3 / number of data axes
NAXIS1 = 3434 / length of data axis 1
NAXIS2 = 1381 / length of data axis 2
NAXIS3 = 3 / length of data axis 3
EXTEND = T / FITS dataset may contain extensions
COMMENT FITS (Flexible Image Transport System) format is defined in 'Astronomy
COMMENT and Astrophysics', volume 376, page 359; bibcode: 2001A&A...376..359H
MIPS-FHI= 1. / Upper visualization cutoff
MIPS-FLO= 0. / Lower visualization cutoff
BZERO = 0. / offset data range to that of unsigned short
BSCALE = 1. / default scaling factor
INSTRUME= 'Canon EOS 1500D' / instrument name
TELESCOP= 'Explore Scientific iEXOS100' / telescope used to acquire this image
DATE = '2024-07-08T01:59:53' / UTC date that FITS file was created
DATE-OBS= '2024-07-03T06:16:11.843577' / YYYY-MM-DDThh:mm:ss observation start,
STACKCNT= 240 / Stack frames
EXPTIME = 30. / Exposure time
XPIXSZ = 3.72 / X pixel size microns
YPIXSZ = 3.72 / Y pixel size microns
XBINNING= 1 / Camera binning mode
YBINNING= 1 / Camera binning mode
FOCALLEN= 289. / Camera focal length
CCD-TEMP= 36. / CCD temp in C
FILTER = 'mixed ' / Active filter name
IMAGETYP= 'Light ' / Type of image
BAYERPAT= 'RGGB ' / Bayer color pattern
XBAYROFF= 0 / X offset of Bayer array
YBAYROFF= 0 / Y offset of Bayer array
PROGRAM = 'Siril v1.2.2' / Software that created this HDU
RA = 311.94369 / Image center Right Ascension (deg)
DEC = 30.304774 / Image center Declination (deg)
CRPIX1 = 1544.66743978 / Axis1 reference pixel
CRPIX2 = 337.789031984 / Axis2 reference pixel
CRVAL1 = 311.402104684 / Axis1 reference value (deg)
CRVAL2 = 30.4825820151 / Axis2 reference value (deg)
CDELT1 = 0.000737919684134241 / X pixel size (deg)
CDELT2 = 0.000739132014441676 / Y pixel size (deg)
PC1_1 = -0.0813524791531773 / Linear transformation matrix (1, 1)
PC1_2 = 0.998392270324605 / Linear transformation matrix (1, 2)
PC2_1 = -0.99505062231753 / Linear transformation matrix (2, 1)
PC2_2 = -0.0804988790317037 / Linear transformation matrix (2, 2)
END
