Hello.
4 years ago, I bought a complete package with ASIAIR/ASI2600MC/EAFv1
However, in the last 5/6 months, I have trouble with EAF
At first it had disconnected during imaging sessions.
I have replaced the USB cable by a new one,
I have try several USB port (ASIAIR/ASI2600/Integrated USB of mount) and the disconnections still appear.
I have also replaced the alimentation cable even if, during the problem, the red LED is always powered….
Since last week (return of good weather !!), the behavior is a little bit different!!
It was the first time since I upgrade ASIAIR in release 2.1.5.
The EAF is not detected at startup….
I must remove cable and reconnect.
And then EAF is detected, and I can go in menu to activate it
When I say I remove cable, it is on EAF side.
If I remove on ASIAIR side, not solve because not detected
It seems to indicate an EAF issue....
On a previous attempt, I flash the firmware of EAF to latest (3.3.8) w/o improvements…
Any idea ?
