@PMTeam@ZWO
I would very much appreciate it if you could also set the gain of the guiding camera per filter in the autorun, in RGB I need a low gain, e.g. 100, but for Ha, Sii and O3 I need a very high gain, e.g. 450.
As it is now, I can't run an autorun with all filters, because the guiding then no longer works when I switch from RGB to narrowband, because then it can't find a guiding star. The other way round, from narrowband to RGB, the image is overexposed and the guiding doesn't work either.
Please consider this possibility in the next update
THX & CS Sascha
