I used it 1 week ago and wanted to charge it a little to use it now. When I plug it in or press the power button, it does not turn on or the red light does not turn on.
CerenKonuk I would disconnect the battery then reconnect and then charge it. First then I would try to start the device.
But seems strange that the battery is drained so fast.
I'm about to cry. What could have happened?
LA3QMA
How do I do what you mentioned?
CerenKonuk Its in the manual. Disconnect the battery for a few seconds and re-connect. Find a proper USB charger and connect the cable to this and the seestar. Let it charge for some time. Then try to power on again.
Does any of the LED light up?
LA3QMA thank you so much. It worked 💖💖
Just to be absolutely sure, you need to press and hold the power button until you hear a beep. Simply pressing it and releasing immediately will not switch it on. You probably do that so sorry for this very obvious comment!
Also the suggestion from wvreeven is a good one as i often my selves has been to quick to turn it on. But if the battery is to low (after long storage) or the S50 for some reason has not shutdown properly you have to remove the battery, re-connect and charge first.
I suspect the reset button on the underside of the base will solve most problems
