Ok, I don't know what's going on, but I was out imaging with my dual setup in NINA. Autofocus worked just fine when I started, but when it came time to do an auto refocus (60min), both instances failed. It took me a while to figure out what exactly was going on. But for some odd reason the EAF's had swapped instance! So EAF1 that was assigned to Instance1, was now controlling Instance2, and vice versa. But nothing had changed in NINA, so HOW?!
Anyway, I disconnected, and swapped them around. But when I reconnected, one of the EAF's popped up with this:
This is not true! Both have the latest firmware!
So far this has only affected the EAF's, and not the EFW's or cameras (ASI585MC).
What is going on here?
