• SDK & Driver
  • Image captured cannot save to disk in the ASCOM driver
I am using an ASI6200MM and SGP, and often encounter an error during image capturing.
The driver being used are:
  • ZWO_ASI_Camera_driver_Setup_V3.24
  • ZWO_ASCOM_Setup_V6.5.25
The following error is found in the SGP log, marked in BOLD.
Could the support look into this suspected issue in the ASCOM driver?
[08/28/24 19:46:34.396][DEBUG][Camera Thread][SQ;] SGM_CAMERA_CAPTURE message received...
[08/28/24 19:46:34.398][DEBUG][Camera Thread][SQ;CC;] SetAscomNormalSpeed...
[08/28/24 19:46:34.398][DEBUG][Camera Thread][SQ;CC;] Cannot set readout speed, not supported by camera...
[08/28/24 19:46:34.400][DEBUG][Camera Thread][SQ;CC;] ASCOM Camera: exposure started, waiting...
[08/28/24 19:46:34.582][DEBUG][Sequence Thread][SQ;CC;] EventMarker(13) - t:Cal2 (0); e:0; f:79; o:
[08/28/24 19:46:37.407][DEBUG][Camera Thread][SQ;CC;] ASCOM Camera: exposure complete, waiting for camera to report image ready...
[08/28/24 19:46:37.420][DEBUG][Sequence Thread][SQ;CC;] EventMarker(15) - t:Cal2 (0); e:0; f:79; o:
[08/28/24 19:46:37.423][DEBUG][Sequence Thread][SQ;CC;] Waking from exposure time sleep period...
[08/28/24 19:46:37.424][DEBUG][Sequence Thread][SQ;CC;] Checking to see if the CCD has a temp...
[08/28/24 19:46:37.424][DEBUG][Sequence Thread][SQ;CC;] Saving the CCD temp...
[08/28/24 19:46:37.430][DEBUG][Sequence Thread][SQ;CC;] Entering super dangerous loop to await image completion...
[08/28/24 19:46:37.433][DEBUG][Sequence Thread][SQ;CC;] EventMarker(16) - t:Cal2 (0); e:0; f:79; o:
[08/28/24 19:46:39.221][DEBUG][Camera Thread][SQ;CC;] ASCOM Camera Error : 无法将类型为“System.Object”的对象强制转换为类型“System.Int32[,]”。
在 s0.ik(q8 A_0, tb& A_1, tb[] A_2)
[08/28/24 19:46:39.221][DEBUG][Camera Thread][SQ;CC;] ASCOM Camera: Attempting to abort exposure...
[08/28/24 19:46:39.221][DEBUG][Camera Thread][SQ;CC;] ASCOM Camera AbortImage: Camera state is 0
[08/28/24 19:46:39.221][DEBUG][Camera Thread][SQ;CC;] ASCOM Camera: Camera state is idle, abort not needed...
[08/28/24 19:46:39.221][DEBUG][Camera Thread][SQ;CC;] ASCOM Camera: Blocking until image is aborted...
[08/28/24 19:46:39.221][DEBUG][Camera Thread][SQ;CC;] ASCOM Camera: Image is aborted...
[08/28/24 19:46:39.221][DEBUG][Camera Thread][SQ;CC;] Error while attempting to capture frame...
[08/28/24 19:46:39.222][DEBUG][Main Thread][SQ;CC;] Adding sequence level notification: Error attempting to capture image (see logs for more information).
[08/28/24 19:46:39.268][DEBUG][Camera Thread][SQ;CC;] Sending Notification: Error - Error attempting to capture image (see logs for more information).
[08/28/24 19:46:39.268][DEBUG][Camera Thread][SQ;] SGM_CAMERA_CAPTURE complete...
[08/28/24 19:46:39.268][DEBUG][Camera Thread][SQ;] Camera thread is IDLE...
[08/28/24 19:46:39.443][DEBUG][Sequence Thread][SQ;] EventMarker(17) - t:Cal2 (0); e:0; f:79; o:
[08/28/24 19:46:39.443][DEBUG][Sequence Thread][SQ;] Image reported as complete. Continuing...
[08/28/24 19:46:39.583][DEBUG][Sequence Thread][SQ;] Collecting FITs headers...
[08/28/24 19:46:39.584][DEBUG][Sequence Thread][SQ;] ASCOM Camera: Could not get last exposure start time. Reported as (unknown)
[08/28/24 19:46:39.584][DEBUG][Sequence Thread][SQ;] DATE-LOC time provided by SGPro (failed to retrieve valid entry from camera)...
[08/28/24 19:46:39.786][DEBUG][Sequence Thread][SQ;] Clearing timed monitoring events...
[08/28/24 19:46:39.787][DEBUG][Sequence Thread][SQ;] Error saving ASCOM image. : 未将对象引用设置到对象的实例。
在 s0.gw(rf A_0, List`1 A_1)
[08/28/24 19:46:39.787][DEBUG][Sequence Thread][SQ;] Failed to save image to disk!
    Subaru Could you test the camera in NINA via ASCOM as well? does the problem appear? thanks.
    Thank you for your reply.
    I will try to install NINA in the remote setup, and test again.
    Write a Reply...
