Mapleleaf Here's a sample image shot at 1.5s @ gain 75 in a Bortle 4 location with heavy dew.
You said it yourself, it is dew on the objective of the guide scope.
Notice that your stars are in good focus; nice small points of light (so, it is not a gross focus problem). But each star has a halo, that is indicative of what dew near the optical axis does to the point spread function.
If the dew were even across the objective, the entire star field would be blurred, instead of looking like stars with halos. So, this is likely to be a case of an onset of dewing, where the outer parts of the objective (warmer) has not yet dewed.
Further, I agree with Tech@ZWO that this is not caused by dew on the camera window. Dew starts at the center of a round glass (coldest part of the glass). If the dew were near the sensor (for example, the camera window), you will have a circular central part of the image plane where the stars are degraded, while the stars are not degraded towards the corners of the guide frame. Your halos appear to be spread out evenly.
Use a longer dew shield and good dew heater, and the problem should go away. Keep your OTA objective over the dew point. Occam's Razor says it has nothing to do with the camera.
(I have no idea why tech@ZWO suggested using a UV-IR cut filter! )
