I have noticed several problems/bugs with 2.2.1
For this report I am attempting planetary imaging of Saturn and Jupiter. I will outline my equipment, problems observed and solutions that ZWO could implement to fix them.
My hardware configuration for this report LX200 F10 8" classic EMC OTA mounted on an AM5 mount ASIAIR+. ASI676mc planetary camera set to high gain, ASI178mm guider, EAF focuser. UV/IR filter. I live under bright Bortel 8/9 sky's.
Side note: to attempt planetary imaging you must use a minimum of F10 for image scale and must use long exposures to detect enough stars for asisir plate solve to function. I am using the largest pixel count planetary specific camera (2um pixels) ZWO makes. These details are important when considering my conclusions later below.
Here are my observations
1 - PA randomly fails with not enough stars after first rotation because exposure is artificially/unreasonably limited to 10 seconds and bin2. Recall you must use at least F10 for planetary imaging so longer exposures are an absolute must.
2 - plate solve with a bright planet like Saturn in the field always fails even with a large enough number of stars visible. I don't think plate solve is rejecting saturated regions and or not exposing long enough. If I move anywhere at all off target I can solve manually with longer exposures at bin 3. Asisir should reject saturated objects.
3 - autofocus also fails with a bright object in field because it's not rejecting saturated objects and attempts to use the brightest and likely saturated object.
Rejecting all saturated objects would fix this and a host of other issues.
Problem
The combination of these errors makes automated high resolution planetary imaging impossible to do.
Even the biggest camera ZWO makes would fail like the asi676mc because they would need a Barlow to scale to upto the optimal pixel scale.
Solutions
Allow longer plate solve exposures and higher bin settings
Reject saturated objects for plate solve and autofocus..
Increase the resolution of the astronomy.net plate solve database to better support F10 or higher focal length telescopes. These longer focal lengths are an absolute must for for planetary imaging
Thanks
PS I do like my asisir and related cameras - hope you find these bug reports helpful
