Kevin_A
Limiting HFD won't help in general, since HFD does not change once a star becomes unsaturated.
The problem with ASIAR multi-star guiding is a combination of these two factors:
1) ASIAIR uses a SNR-weighted centroid average (told to me by the ZWO developer while it was being implemented a couple of years ago). I.e., if you have a star with extremely good SNR relative to the rest, it will carry all the weight, and end up representing the case of no better than one-star guiding.
2) stellar magnitude distribution. Take a look at the HYG catalog, which contains pretty much every star that a guide scope can hope to see.
https://www.astronexus.com/hyg
If you plot the distribution of stars, you will find an exponential type tail. I,e., there are many more Mag 0 stars than there are Mag 1 stars, there are many more Mag 1 stars than there are Mag 2 stars, etc. Because of this effect, even if you get rid of saturated stars (all unsaturated stars should show the same HFD with a good guide scope, independent of brightness below saturation). So, because ASIAIR is using SNR weighted centroid averaging, the brighter stars will still hog the centroid, and you end up with the equivalent of only 2 or 3 stars even if you see 12 stars on the ASIAIR display. This is equivalent to changing from 1 second to 2 to 3 second exposures to average out "seeing" for single star guiding.
You cannot avoid this unless you change the centroid averaging algorithm from a SNR weighted one.
Prior to v1.5 or so, ASIAIR would religiously ignore saturated stars, so you can basically increase the guide camera gain to the point where you can make ASIAIR ignore magnitude 2 or brighter stars.
Each magnitude is a factor of 2.5 in ADU, or about 12 dB between magnitude 0 and magnitude 2 -- so that gives you an idea of how much extra gain needs to be applied to ignore dimmer stars. That had worked very well (when using ASIAIR, I had increased the gain by 10 dB after ASIAIR first sees 12 stars), at the cost of slightly noisier guide images (but, still better than allowing bright stars to hog the centroid averaging).
Unfortunately, the recent ASIAIR (at least since v2 beta) no longer ignores saturated stars. It will even choose Vega. The only way now, as long as you want to keep using ASIAIR, is to move the guide scope so that the FOV is pointed at a region of the sky where there are fewer bright stars. We used to use x-y stages to find a reasonable guide stars in the good old days, now, we need to use the x-y stages to ignore bright stars!
(Another usability bug in v2 is they are now sampling the mount position much slower now (perhaps once every 10 to 15 seconds), so when you slew (or meridian flip the mount), you will not see the mount coordinates change. There are multitudes of lesser bugs. )
I had not fed back beta anomalies in v2 beta because ZWO now requires you to enter an email address, and hell if I am going to give ZWO yet another email address for their marketing department to spam.
Both the bugs above got to their general v2.0 release.
