Is there anything to consider when using the seestar with an angle and aligned to the polestare to remove fieldrotation? I´m asking because the device will be not centered on his base in this usecase. Can this cause any damage?
It's not recommended by ZWO but some users have used an equitorial wedge. Watch the YouTube video for an explanation. https://youtu.be/8_qyMm7-ftg?feature=shared
Seestar_S50 Thank you for the reply. Why is it not recommended? What concerns or problems do you have / see?
One concern would be that this will put a lot more stress on the bearings and gears in the base of the scope than in the usual alt/az configuration for which it was designed.
