I have an ASIAIR pro on my AVX mount, and an ASIAIR plus 32gb on my am5. There were no issues on either rig before these updates. Build 11.26
1) on the Plus/AM5, it plate solves just fine in preview. It also plate solves just fine in polar alignment as it tilts the scope, then for 2 or 3 plate solves as I get things dialed in…then it just fails. Repeatedly. I have shut down and started over with the same result.
2) on the Pro/AVX, I can connect and see everything in the interface, but it won’t connect to the hand controller of the AVX. I’ve tried selecting Celestron AVX as the mount, and I tried Eqmod. Both say that it is failing to connect and to check the baud. It was working fine before the updates. (When I changed it from Celestron Avx as the mount and set it to eqmod, it slewed itself to point the scope straight down, but still refused to connect??!!
Here’s the weird thing. I swapped the stairs so the pro is on my am5. Works fine.
But putting the plus on the avx yields the same problem as before.
This is after an update screwed things up and they quickly released another update.
does anybody know anything? I have not seen complaints about the AVX issue yet, but I had seen issues regarding polar alignment.
