I updated the hand controller and mount firmware last night, and aligned the scope using the star atlas 'synch' procedure. However, while RA will cycle 90 degrees left and right from home, Dec will only go about 45 degrees. I will either try aligning the tripod so the scope is aimed at my artificial star using RA only, or I will try switching to alt/az mode on the mount and see if that will work. Additionally, I am now concerned that something may be malfunctioning in my mount.
Somewhat related, ZWO no longer has a mount app (required to update the firmware) with a ZWO or ASI name for Android--it was ASIMount. Instead, that functionality is now in the SkyAtlas app. It took me quite a while to find that.
