I have an ASI 2600 MC pro. I would like to know if it is normal that at an ambient temperature of 23º C, to lower the sensor temperature to -10ºC the cooler has to work between 93% and 95%. Is this normal? Does it harm the camera? Thanks.
raurgo that is normal. It has a cooling capacity of -35c ...so at 23c-35c =-12c max. Do you ate bear max.
So having the cooler work at 95% or 99% is not dangerous for the camera?
Thanks Kevin
raurgo It's ok, but too high power which causes the cooling temperature to be a bit unstable.
