Jay6879 Hi, do not do this. The main purpose of the heavy load mode is to enhance the load capacity of the equipment under low-temperature conditions (as low temperatures can weaken the load capacity of the equipment), ensuring normal usage with a load capacity of 15kg/20kg (with weights). It is not intended for prolonged use under significantly higher loads exceeding 20kg, as doing so may damage the equipment.
