I have been using this combination on my 11" Edge on an iOptron70 mount to image Jupiter.
When focusing I actually like to do it manually and from experience with SharpCap I use video mode.
The issue with the ASIair 7 662 combo is that in video mode the ROI defaults to 480, Far too small when finding and focusing. You need a much larger ROI. But if you set a larger ROI and for whatever reason you need to go back to Preview or Focus and then go back to Video it defaults back to 480. Why?
I am now using Sharpcap as its control of exposure and gain is much better , plus I am getting a better frame rate (60+ FPS) as compared to the ASIAir of just about 10 FPS if I am lucky.
On another matter why is the ASIair so poor a finding a planet? Jupiter, Mars the Moon are always never in view when I do a goto. Much the same issues as you have and I have experienced with the Seestar50 when trying to locate the Moon or the Sun.
My Jupiter the other morning when using the ASI662 &
Sharpcap
