rrosenberg8 Any suggestions of the best way to move images from the ASAir to a Mac?
Connect the ASIAIR's LAN port to your home router's Ethernet switch. Forget about ASIAIR WiFi; it is crap.
In the macos Finder's Go menu (in menu bar), select "Connect To Server."
Click Browse in the "Connect to Server" window.
You should see ASIAIR.
Click on the ASIAIR icon, and you should see the different ASIAIR volumes (EMMC Images, TF Image, Udisk Images). If you had save the images to a USB Flash Drive or an SSD to ASIAIR, it will be the Udisk (USB Disk).
Double click on the volume and macos mounts it to your desktop, just like any other external drives, using Guest as the user; no password needed. You will probably see its URL with a smb:// prefix (Samba server) -- Samba has been on MacOS for at least 25 years now.
Drag copy the ASIAIR files, etc, to your own drive, again, just like any other external drive.
When done, eject the ASIAIR volume before powering the ASIAIR off, or removing ASIAIR from the router.
ZWO has a bug which causes the server not to eject successfully every time. If so, you can get rid of the orphaned server from your desktop by going to macos Terminal, and issue the Unix command "killall Finder".
