Sonixx
You will always experience quality variations on a product that meets the set quality standard. While what you see is not perfect, but not too bad for a €700 includes it all plastic scope.
Ok, I agree with that, except that other telescopes usually allow you to adjust the collimation, which is not the case with the S50, and 700€ is a considerable amount to demand a minimum of quality. It is not the first telescope I have had, my Meade ETX 80, despite being achromatic, does not show aberrations of this type and is half as cheap. It is true that it does not have an LP filter or autofocus, but at least the optics meet a minimum of quality.
You have to spend way more if you want to go next level, but problems with bad stars in corners still commonly exist. And kit gets much larger.
I have a larger Newtonian telescope, and HEQ5 mount, guide scope,... I bought the Seestar S50 so I could do more astrophotography, and honestly, of all my telescopes, this one has the worst collimation problem, and it cannot be collimated.
If it is still in return policy period, send it back and get a refund, in case you can‘t live with it.
Yes, I'm working on that with the store, I hope I can return it.
And thanks for sharing your point of view.
