starlancer how am I supposed to downgrade if I can’t connect to it since wifi isn’t working
If WiFi is the problem, don't use WiFi.
Get a CAT6 or better Ethernet cable. Connect the LAN port of the ASIAIR to a LAN port on your home router. The ASIAIR app on your tablet should see the ASIAIR device.
If the app still cannot automatically find the ASIAIR device, look for the address of the ASIAIR on your router, and enter that as the manual IP in the ASIAIR app. Pretty much every "auto" function in ASIAIR is broken; you are better off using INDIGO Sky or StellarMatePro if you depend on "auto" functions.
If you are using iOS or iPadOS, be sure to go into the ASIAIR app settings on your Apple device to allow Local Network connections.
