Hi, thanks for the response.
What do you mean by "According to your guide log, your DEC guide mode is set to "North". The DEC axis in log 1 and log 2 shifts in opposite directions, making it impossible to make effective corrections."?? Please explain further. Are you saying the drift is caused by the DEC set to North? Should I always have it set to Auto to prevent this drift?
OK so the rms of a single frame is 1.76", yes that makes more sense. Still this is very high as I try to keep it below 1".
Shouldn't the Asiair change the DEC setting automatically before and after, a meridian flip or does it only do that when it is set to Auto? Example.. So if it is set at North say before a meridian flip, then after the flip it should automatically change it to South?
Thank you for taking the time to look at my graphs and explain. I will try again on a clear night, when we get one, to see if I get DEC drift again if set to North and then change it to Auto to see if it corrects it.
cheers Nick
