here's some screenshots...
asiair explicitly provides feedback: limit for EXP/s max 30 secs. (it shows when I manually enter an exposure value when creating a light sequence in autorun mode.
Similarly, the shutter choice in preview doesn't exceed 30secs.
However, when I go and enable the shutter release cable I can select all the way up to 1000secs in preview mode. (I tested up to 300 seconds) as shown here in preview mode whilst selecting exposure:
From my experience with both 5DmkII and 5DmkIV, that 30 seconds is just fixed in the camera. If you want more... use a TC-... exposure timer connected with the shutter release port. That's just how these particular two camera models work (note that I'm limiting my specs to the camera's I own(ed) and used for long exposures regularly.
And here's the thing:
in autorun (and plan) mode, I want to do sequence runs that have not only darks and lights, but I'd like to include bias and flats too. And this is where autorun and plan modes have an issue:
For exposure reasons I need 5 minutes of exposure on my lights/darks. Thus I need to enable the shutter cable.
However when I add biases at 1/4000 to that autorun, the biases simply don't get taken (the camera stays quiet infact).
Similar for the auto flat mode (where asiair goes through an exposure seqence to determine optimal flat exposure time), no flats get taken, presumably due to similar causes as the biases.
Jumping the gun a bit: a way of addressing this in the software would be for the asiair to decide (based on exposure time required) to use either the bulb cable or trigger exposure manually when the bulb cable is enabled.
Hope that clarifies/answers your question?
summed up: it is what it is with this camera model. however, when enabled, asiair "borks" autorun plans with short biases and auto flats.
