xfirf
Hi!
I had the same problem!
The arm does not open after the update! I did everything exactly as before!
turns on, waits, connection, check...the lever doesn't open! If I enter automatic aim, then neither, if I choose Scenery mode, the Seestar moves left and right, but the arm does not move up and down! After that, moving left and right doesn't work either!
