I had the same issue yesterday. Bright line, couldn't find focus.
On your pic this is not the Moon, but a reflection on the black plastic edge right in front of the Seestar lens. If you move Seestar a bit with the screen joystick (Slow!), you find the Moon very close to the actual field of view. Dew shield helps to avoid this issue.
